Leaking Super G
I have a Super G that has been on the bike since 97 No issues, had a master rebuild kit installed back 2004, only because the engine was being stroked, and it seemed like a good time to do it.
Out of the blue last week it started leaking gas and getting progressively worse. The leak started at the overflow hose and got progressively worse, now it is overflowing so bad that gas is coming out the vent hole on the air cleaner mounting surface.
I figured it was a bad float valve and seat, so I replaced them. Still leaks, no change. Next thought was a bad float, you know not coming up all the way, so I replaced it and the carb still leaks.
Other than this gas leak issue, this G has been maintenance free for many years. Nothing has been changed recently to attribute to this new leak.
Any ideas?
