Custom DynamicsJekillandHyde.euMotorcycle-CommunicationCycleGear.comLeslie Kay'sSportbikeTrackGearProCharger.com
JardineProducts.com
R&R Cycles
Old 04-15-2009, 06:17 PM   #1 (permalink)
heavyduty is on a distinguished road
Running out of gas
95" twin cam open air cleaner S.E.cv 44 carb. Run great til 3500 rpms. Seems to be running out of gas. Check float adj.If I bend float tab anymore, carb overfills. Petcock has good flow. Jets in the carb are 48 slow, 195 main which is what I have run for a couple years. Any suggestions what the hell is going on with thing? I don't think that it is an ignition problem but don't know? Thanks!
heavyduty is offline   Reply With Quote
Old 04-15-2009, 09:08 PM   #2 (permalink)
Livin' the life
Mother's Avatar
Mother is on a distinguished road
Is it the stock petcock? I had to switch to a Pingel. It was running out of gas shifting in to 3rd gear on the dyno. Swapped petcocks and problem fixed.
95" new dyno sheet soon 11:1cr Triple XXX S&S carb w/Green filter
Axtell Prostreet Pistons
SE roller rockers & rocker support
Fueling cam plate, oil pump, & 'B' lifters w/limiters
Leineweber T7 .603" gear drive cams
Larry Long portwork
TwinTec ignition
Baker Clutch
Vance&Hines Outlaw 2into1
3.37's
Pirelli tires
Amsoil
Mother is offline   Reply With Quote
Old 04-16-2009, 08:03 AM   #3 (permalink)
It is not stock aftermarket high flow, pulled hose off at carb, good flow
Old 04-16-2009, 01:21 PM   #4 (permalink)
rcsoftail is on a distinguished road
Are you sure the slide is raising? Mybe you have a hole in the rubber diaphram or it is not fully seated, which will keep it from opening. Do you have another ignition you can plug in to make sure there's nothing wrong with the rev limiter?
rcsoftail is offline   Reply With Quote
Old 04-16-2009, 01:57 PM   #5 (permalink)
mooooving out!
route66paul's Avatar
How is the accelerator pump?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 04-16-2009, 02:21 PM   #6 (permalink)
This is a problem I have been fighting for some time. Adjusted float due to fuel in the air filter. This is a fairly new carb. But I did look at the accelerator pump and diaphram, looks good. I can run the bike past 3500 rpms but after about 5 seconds starts backfiring out of carb just as if it was running out of gas. Ignition is a screamin eagle for a 1999 bagger, I think the rev limit in it is 7000rpm, but not for sure. Someone had mentioned exhaust problem, which I had changed the exhaust and I can't remember but that might be when all of the problems started, gas in air filter. The exhaust I put on was a Thunderheader
Old 04-16-2009, 11:43 PM   #7 (permalink)
If it started with the exhaust, that's where I would start. I think those have some sort of vanes for baffles. Maybe one has broke and is causing blockage when past 3500rpm. I think an exhaust blockage could cause the results you are seeing.
Old 04-17-2009, 12:48 AM   #8 (permalink)
Thanks! Will try previous exhaust. Will let you know! Thanks!
Old 04-17-2009, 07:53 AM   #9 (permalink)
springer-'s Avatar
Also check your fuel line routing. If the fuel line is touching the engine, cylinder, heads etc it could be causing a vapor lock in the fuel line. This is especially true if you have an in-line fuel filter. The in-line fuel filter can get hot and cause a vapor lock. When this occurs, the fuel flows great when checked but only flows enough for lower RPM operation when the engine is running. If it has a in-line filter, remove it and run a straight line to the carb. Make sure it doesn't touch anything hot.
207-621-8089
