CycleGear.comProCharger.comMBO EnterprisesRRcycles.comJardineProducts.com
Motorcycle-CommunicationDan Vance Racing
Old 04-06-2009, 11:03 PM   #1 (permalink)
20nighttrain03 is on a distinguished road
EFI to carb problem
took me more time to research this swap than to actually do it! (being a master auto technician for the past 8 years may have helped)
wiring was very easy BUT i have one problem
i swapped from a delphi EFI on a 2003 night train to an S&S super e with a brand new carb-style coil and a used ICM
fired right up with the first touch of the starter buton
here's the glitch though:
as soon as i start the motor the engine light comes on (ran the flash code and came up with codes 24, 25 and 42)
24 and 25 are for the coil (hi/low/shorted)
i have nothing in any of my service manuals for a code 42 though
i tried to take it up and down the block to jet the carb, but as soon as i hit (well, atleast what i think is) the tranisition from the intermediate jet to the main jet it breaks up bad (feels like more of a spark miss than anything else)
thinking i needed to jet up i swapped in a few larger main jets
no dice
definetly a spark problem while under load
checked the spark at idle with my spark tester and it looked healthy
this would seem to agree with the 2 trouble codes i have for the coil
i TRIPLE checked all my wiring making sure that:
1)nothing is shorted to ground
2)nothing is shorted to voltage
3)power is where it is supposed to be, when it is supposed to be
4)ground is where it is supposed to be, when it is supposed to be
5)good continuity on all circuits from and to the ICM
i am thinking i got a bad ICM.......(i did buy it used offa ebay)
i tried running the EFI coil, but had this probelm so i ran to the harley dealer and grabbed a brand new carb coil
no dice, same symptoms
at a loss here really.....bike ran great with the EFI, bought a street glide last year, so this one is now the barhopper (even though i dont drink anymore)
any help would be appreciated!
20nighttrain03 is offline   Reply With Quote
Old 04-06-2009, 11:12 PM   #2 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
are you loosing the crank postion sensor input? sounds like the ignition is loosing its postition..
you cant use a EFI coil as it has a very different resistance than the carb coil..
good luck
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote
Old 04-06-2009, 11:24 PM   #3 (permalink)
not sure if i am loosing the crank sensor input
(checked the wiring on the circuit though- everything was ok before the swap, circuit checked out A-OK)
yes, i am thinking that maybe by attempting to use the EFI coil at first i fried the ICM
like i said i swapped over to the correct coil tonite and still the same deal
feels like i am hitting the rev limiter if i give it anything more than say 1/4 to 1/3 throttle
Old 04-06-2009, 11:28 PM   #4 (permalink)
this is the part number on the ICM:
32568-00A
i am also wondering if this is the early ICM and it is looking for a cam position signal (which, being a 2003 this bike does not have)
an out of tune carb would not cause these codes, would it? i wouldnt think so..........
also has no codes stored for the crank sensor
thanx so far!
Old 04-06-2009, 11:49 PM   #5 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
I think you hit the nail on the head. I'd bet the ignition module is for early TC's with cam position sensor. Look for a SE Adjustable MAP ignition module for carbed bikes. Might find one on eBay and it's doesn't require the cam position sensor.
Ed Y
2002 FLTRI
I yam what I yam.
Ed Y is online now   Reply With Quote
Old 04-07-2009, 12:02 AM   #6 (permalink)
i think i did as i just google'd HARLEY CAM POSITION SENSOR DTC
i came up with a DTC code 42 (which my bike is throwing at me)
guess i got the wrong module!
THANX GUYS!
i will keep ya's updated on the fix
Old 04-07-2009, 09:26 PM   #7 (permalink)
yes sir......wrong module
referenced the part # and it is for a 2000 softail...which is why it is looking for the cam sensor signal, poor thing doesnt know if its coming or going on my bike
i know it is going LOL
