I agree, don't get rid of the CV. You can upgrade it with a ThunderJet kit, they are about 45 bucks from Jireh. I have the one for the CV here, wrong one for my super G carb. As for the exhaust, I put a set of torque cones in my buddies twincam softail. He was runnin straight pipes and complained of a loss of lowend. I just pulled the pipes, put the cones in the head end of the exhaust and bolted them back up. He noticed it right away. You can also do the washer welded to the bolt trick. You will make a "lollipop" with a washer and a bolt, and insert them at the end of your pipes. You have to drill a hole in the bottom of the pipe. Then you just turn the washer until you find the happy medium your looking for. All it does is create the back pressure needed to scavenge exhaust better with drag pipes. Also, you didn't mention if the pipes were 1 3/4 inch or 2. If they are 2 in, your not going to make them better. 1 3/4 in pipe that's it. Unless your running a 100 in motor or bigger.
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
