Diamond Bar ChoppersMBO EnterprisesJardineProducts.comAdvanstarMotorcycleShowsPro PadDan Vance RacingRRcycles.comSportbikeTrackGearMotorcycle-Communication
JardineProducts.com
Old 03-04-2009, 06:03 PM   #1 (permalink)
tattoo1 is on a distinguished road
can float level keep engine from starting
Is it possible if fuel level is to low in bowl bike will not start at all?
May seem like a dumb a** question but close to my wits end on
my attempt at fire up after engine work done. I have fuel thru nozzle and have pulled plugs and are wet or I should say damp. I smell gas when plugs pulled as well. I reworked this carb and set
float by book but will check again if above is possible.
I have another thread running at another location and will be checking timing for possible no fire/run issue.
Thanks for any input.
tattoo1 is offline   Reply With Quote
Old 03-04-2009, 06:18 PM   #2 (permalink)
if you get a spray from acell pump when you twist the throttle, it should run. if float was too low, you wouldnt have wet plugs. i would suspect a weak/no spark problem, you have replaced plugs right? you cannot clean or fix fuel fouled plugs.
Old 03-04-2009, 06:46 PM   #3 (permalink)
Yes I did put in brand new plugs and got it to fire somewhat after putting fuel in thru plug holes. I will check on timing issues before I take carb off again. Plugs had good spark which is what confused me when nothing happened prior to putting fuel in thru plug holes but I also moved timing as well. It appears I may have run out of timing adjustment since it halfway runs against full clockwise turn of sensor plate. Will not fire if go other way much at all.
Thanks Claydbal..
Old 03-04-2009, 06:59 PM   #4 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
What sort of "engine work" was done just before this problem cropped up?
Old 03-04-2009, 07:24 PM   #5 (permalink)
Had a local shop put in rings w/ 10:1 pistons, cam bearing w/ ev38cam and new rocker boxes with adjustable pushrods. I tore down the bike myself and took engine in for work. I as well put engine back in along with new clutch basket , primary chan , etc. The carb is a CV which I changed jets to a 45 / 180 and went with scream'n eagle breather set up. This is on a '89 evo.
Thanks for your inquire Jerry.
Old 03-04-2009, 07:35 PM   #6 (permalink)
Thanks Claydbal..
turn petcock off, spin motor till you clear fuel with throttle open. next, spray wd 40 into plug holes. about a 6 second blast per hole. install plugs and hold throttle open about halfway, see if she fires. be prepared to keep spraying wd40 into carb to keep running, this will help diagnose.
as asked above, what changed? which ignition unit do you have?
Old 03-04-2009, 08:00 PM   #7 (permalink)
still running stock '89 equipment w/ dual fire coil. I will give the
wd40 a shot tomorrow as need to charge battery from earlier attempts to fire. I will also set static timing prior to any attempts so hopefully close.
Old 03-04-2009, 11:18 PM   #8 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
Cam out of time?
Old 03-05-2009, 08:36 AM   #9 (permalink)
Originally Posted by jerry34208 View Post
Cam out of time?
probably, or ignition module installed and static timed on wrong TDC mark? but the wd40 will tell what the problem is (probably)
Old 03-05-2009, 10:58 AM   #10 (permalink)
nmaineron is on a distinguished road
I think you are going at it backwards.Get your timing set right first.If you know how to static time it, do it. You are running a lot more compression you have a tight motor and your battery is weak,fuel isn't your issue if your plugs are wet.
nmaineron is offline   Reply With Quote
Old 03-06-2009, 08:16 PM   #11 (permalink)
No Compression
Bought a compression tester cause nothing was making since. Not
sure what the shop I had work on motor did but had 170 lbs on the
front jug and ZERO on the back. Probably pushrod adjustment
issue but I paid for a motor that would run and the shop has it to give me just that.
Thanks for all the input and suggestions.
Old 03-07-2009, 10:32 AM   #12 (permalink)
Tattoo,do yourself a favor and take your rear pushrods down and check to make sure that you have closed valves.
Things do happen.
If you are running hydraulics the lifters should have bled down and if anything should have been slack.
Solids would be too tight.
When you did your comp. check did it just show zero or did it have a high point and leak to zero?
Old 03-14-2009, 04:47 PM   #13 (permalink)
Pushrods way out .....
Bike running now. Rear jug pushrods had valves open. Fronts were out some as well which would not allow it to even fire.
Just have to fine tune carb and be on the road I hope.
Thanks to all who replied to this thread....
