Keihin 27029-88 carb ID : V-Twin Forum: Harley Davidson Forums
Old 04-11-2008, 08:53 PM   #1 (permalink)
jior's Avatar
jior wants to know Dino or Syn?
I bought this used Keihin carb, sticker #27029-88. I'm looking for the float bowl gasket and accel. pump part #'s. Or can anyone tell me what this carb may be off of, so I can go to the stealer and order the parts. I'm assuming an '88-'89 vintage evo or T.C.. Thanks for any help!
jior is offline   Reply With Quote Quick reply to this message
Old 04-12-2008, 08:51 AM   #2 (permalink)
bagga's Avatar
bagga wants to know Dino or Syn?
the last two numbers after the - is always the year it was first used or made. so it's off an 88 model of some sort.
bagga is offline   Reply With Quote Quick reply to this message
Old 04-16-2008, 10:36 PM   #3 (permalink)
Guns64 wants to know Dino or Syn?
I guess timeing is everything. I have two post on this site looking for info on that exact carb. I have a 27029-88 on a 88 E-Glide Harley. 88 is also the last year HD used them on the big twin before going to the CV's. Rebuild kits are available at HD shops for it. I need info on setting it up and tuning. The carb is on my sons bike. He's added a high flow filter and pipes and now we have a lean pop. It has a 165 main jet but not quite sure what is the low jet on it. I also need to ID the idle curcuit. Looks to have a plug over it like the stock CV do. Can you help with info ??
Guns64 is offline   Reply With Quote Quick reply to this message
Old 09-08-2008, 10:25 PM   #4 (permalink)
No one rides for free
Bud Man's Avatar
Bud Man wants to know Dino or Syn?
Here is a break down of all of the parts, and quanity to that carb, hope it helps.
27130-81 SCREW, CARB 1
27136-81 SPRING, CARB 2
27137-81 WASHER 2
27143-81 PUMP LEVER ASSY 1
27144-86A CHOKE LEVER ASSY 1
27145-81 SCREW 1
27304-76 SCREW, CARB 1
27307-76 SCREW, CARB 1
27308-76 PIN, CARB 1
27309-76 SCREW, CARB 1
27311-76 CARBURETOR BOOT 1
27324-83 O-RING, CARBURETOR BOWL 1
27325-86 CHOKE WIRE BRACKET 1
27329-83 SLOW JET 1
27333-76 SPRING WASHER 1
27335-76 NUT 1
27360-76 O-RING 1
27361-76A DIAPHRAM, ACCELERATOR PUMP, CARB 1
27362-76 SPRING, ACCEL PUMP DIAPHRAM 1
27366-76 SCREW, CARB 5
27367-76 SCREW, CARB 1
27368-76 CLIP, RUBBER TUBE 1
27369-76 RUBBER TUBE 1
27370-83 ROD 1
27371-76A L-JOINT, FUEL INLET, CARB 1
27385-76 PLUG, CARB 1
27886-78A FUEL VALVE W/CLIP 1
27887-78 FLOAT, CARBURETOR 1
27898-78 MAIN JET 1
Bud Man is offline   Reply With Quote Quick reply to this message
Old 09-09-2008, 01:36 AM   #5 (permalink)
Buddy Seat's Avatar
Buddy Seat wants to know Dino or Syn?
Unless you are going for original, a CV is a very worthwhile upgrade..
Also: the term 'keihen cough' was named so for that carb, you have.
Bud
Buddy Seat is offline   Reply With Quote Quick reply to this message
