Progressive Insurance
Motorcycle.com Classifieds!AmericanMotorcyclistAssociationMotorcycle.comArnottAirRideWheeldock.comRosa's CycleSpringfield ArmoryMetalArtsStoneyStraps.com360 Brake CompanyExtreme Custom Engraving
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > General Discussion Forums > Buell Motorcycle Family General Discussion
CycleGear.com
Old 07-06-2007, 10:21 PM   #1 (permalink)
Comming Through!
FLHP
Blast
Bought a used Blast for the wife a little while back. She rides some, but not a bunch. Thought I might keep it to bomb around on a little. Anyone done any carb work on one. It's so gutless on the low end. Gotta be able to do something to pick it up a bit.
The only thing more fun than driving 100 is catching someone else.
FLHP is offline   Reply With Quote
Old 07-07-2007, 06:16 AM   #2 (permalink)
they have a class for the blast in AMRA, thumper class i think. you may google that for some info. saw some turning low 15 second quarter miles!
Old 07-08-2007, 09:35 AM   #3 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
Best thing for a Blast is to put an aftermarket pipe on it (Vance and Hines, Jardine, D&D) , an K&N air filter insert, and rejet to
Info shamelessly stolen from Badweb
Stock Jetting
2000 - 2001 42/165
2002 - 2004 42/170
For exhausts that are aftermarket - 45 primary
175 Main
For the Kerker - 45 primary, & 165 to 170 main (until you cut the crossover tube off, run directly from the header the can of your choice - instant top performing system - then you would run the 45/46 primary, & 175 to 180 main)
WB/Force/ & any true performance exhaust with a min. of 1 3/4" od header in combination w/low to no restriction exhaust can:
45/46 primary & 175 Main & shim needle 0.050"
Note 1) 180 main may be a little rich for some exhausts.
Note 2) if live and dwell above 3500 ft - 44 primary
170 main
Final Jetting notes:
Actually a lot of my jetting knowledge is from my various dynos and my observations - hardly a rush - over a year to decide I was still running pretty lean over - all.
My recommendation these days would be:
Stock - 45/170
Exhaust change only - 45/175
Exhaust and intake - 48/180
All at sea level - at above 3500ft. I would have a different answer.
I'd also recommend an Irridium plug - especially the racing - for a more complete burn - you'll instantly notice the difference.
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 08-01-2007, 06:57 PM   #4 (permalink)
happyman is on a distinguished road
Rockbiter,
Can you say what is the best exhaust system for the buel. one that has the tq and all around performance.. i did see a D&D and the money they get for that complete system is as hig as it is for a big twinn.. bu ti guess if it works it don't matter.. also is the vance and hanies slip on a god deal.. and about the airfilter.. is there a # for it and is iut one that fits inside the stock airbox?? am picking up an 02 tommorrow and just may mess with it a bit.. still want the reliability and mpg pretty much too if thats possible.. also is there a metal part that replaces the compliance fittng that goes from the carb to motor?? anyway as you can tell this a bit new to me but have been into the harleys for a lot of years so far i have had 16 ofum and the one i now have is a CVO Roadking..
Thanks Happy
happyman is offline   Reply With Quote
Old 08-03-2007, 01:57 PM   #5 (permalink)
Pebble Cruncher
Rockbiter's Avatar
There is infact a direct-fit K&N filter, BU-5000. The retail price is as high as $65 and as low as $45, depending on where you buy. It should last the life of the bike, properly taken care of.
As for the exhaust, the "bullet proof" setup (which I cannont afford) is a Jardine header with a D&D can. Its supposed to be the best mix of durability, performance, and sound.
There is no metal compliance fitting to my knowledge, but some people have had success with a 2" turbo hose. The key is really proper installation and torque. If you overtighten the hose clamps, you'll be more likely to damage the coupler.
Personally, I run a complete Pro-Series setup, intake, cam, and exhaust. I still need head work, but the bike runs like a pissed off chihuahua :P
Please note, the more the bike is modified, the lower the fuel effeciancy will be. I'm currently getting around 55mpg with my bike, but I ride in the top of my rpm band (thats where my cam and pipe work best, it will be diffrent on your bike)
'04 TC103 FXD
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE Clutch spring
