12-20-2007, 10:26 AM
96" Throttle by Wire, Street legal stage 1 vs. SERT Stage 1 vs. SERT Tuned
The new 08 Touring models have "Throttle by Wire".
What to do to compensate for a stage 1 (air cleaner and exhaust) upgrade on a new 08 touring model? There are several options, the Legal Stage 1 dealer download, A SERT Stage 1 download, a SERT Dyno Tune, PCIII and a ton of other products as well. Lets start with stock ECM. The Harley Delphi EFI system is the most sophisticated EFI system available on a motorcycle today. All the add on products and replacement products, IMO, are a step down from what comes with the bike stock. For me that eliminates all the replacement and add on products like the Tmat, PCIII, DFO's, Race Fuelers, etc.
I recently tuned an 08 Road King. It has an air cleaner and independent duals but is otherwise bone stock, including stock cams. The dealer did a Street Legal (SL) Stage 1 download to the ECM. We did a baseline with the SL Stage 1 download. In hind sight we should have run the full map for a better comparison but we only ran a Full throttle run, you will see that later in the post. After running our baseline we installed the SERT Stage 1 Map and then ran another baseline, this time we ran the entire Map and proceeded to Dyno Tune the engine.
The way we tune is VERY different than 99% of the other tuners out there. This is a huge issue of debate and not one I am going to get into but I will tell you the differences. Most (probably 99%) tune with AFR. The ECM adjusts using O2 sensors that read AFR. Wide Band O2 uses AFR. Many dyno sheet critics look at the AFR on the bottom of the sheet. Aftermarket tuning devices use AFR, like the Daytona WEGO system. Most Dynos have AFR systems built in for Dyno tuning. At this point you should have a picture painted that the industry relies on AFR devices for tuning.
We don't use AFR for tuning, we can't see the AFR, have no way to measure AFR and don't adjust for AFR.
If not AFR, what? We use combustion science to tune the engine. When fuel is burned it is a chemical reaction. The chemical reaction gives off by products, these are the emission. CO, CO2, HC and O2 are all emission in the exhaust gasses. AFR only looks at the O2, the least important in the equation. Carbon Monoxide, CO is partially burned fuel. Carbon Dioxide, CO2 is fully burned fuel. Hydrocarbons, HC is raw unburned fuel. Oxygen, O2 is left over that isn't used in the combustion process. In a perfect world all the O2 is combined with all the HC during the combustion process, this doesn't happen. We look at the exhaust gasses and then adjust for a proper burn. The gasses tell us how the timing is, if there is too much or to little fuel for the amount of oxygen available etc.
I am not saying EFI can't be tuned with AFR. I am not saying that we will get higher numbers tuning without AFR. But I would say the number 1 comment we hear from our customers is "It runs so much smoother now". We have retuned several bikes tuned by some top notch, highly regarded performance shops. Typically we achieve better gas mileage, smoother running engine and more power through out much of the partial throttle range. We don't often obtain better max numbers at WOT but we also don't typically lose power at WOT either.
There already seems to be a misunderstanding of the throttle by wire system. I have seen post about the throttle plates lagging behind the throttle. For example, you twist the throttle and the plates don't open all the way and seem to have to catch up. This is by design and is not a issue of the servo being slow or anything else. The EFI system knows the engine can't use all the air at that RPM and if it were to open up fully it would actually hurt the performance. Kind of like the way a CV carb works. On some types of Dynos the drum is very heavy. When you whack the throttle wide open and the engine is at 1500 RPM's, the EFI will not allow a throttle position of more than 30%. Then as the engine revs increase and hit 1750 RPM's it allows the throttle to go to 40% and so on. The EFI doesn't allow 100% throttle until the engine hits 2750 RPM's. If all that is being observed is the throttle plate to hand grip position it would look like the plate is lagging behind and holding back the RPM's, it isn't.
207-621-8089
12-20-2007, 10:27 AM
207-621-8089
12-20-2007, 10:28 AM
207-621-8089
12-20-2007, 10:29 AM
In the following chart it shows actual torque changes based on Map positions. This is the SERT tuned vs. SERT Stage 1 canned map.
Here is a comparison at wide open throttle between the Street Legal Stage 1, the SERT Stage 1 and the SERT Tuned Map. Earlier in the thread we discussed the Throttle By Wire and the fact that it doesn't allow 100% throttle plate opening until 2750 RPM. Note on this graph the RPM starts at 2000, well below the 2750 RPM required for 100% throttle position. At 2000 RPM there is a 14lb Torque gain over SL stage 1 with O2 sensors, remember this is a STOCK cam. At 2000 RPM's the max throttle position is 60%.
207-621-8089
12-20-2007, 04:36 PM
BEADMAN
All great stuff springer but I can't see the pics just little red x boxes. What's up with that?
2008 Road Glide, little of this, little of that, really quick and fast ...Totaled 8/15/09 Lady ran a stop sign, ouch!
"Ahhh women! Aren't they just the best? I love em all and they all love me!" Denny Crane, 2007
12-20-2007, 06:16 PM
Axe Man
Did you retain function of the 02 sensors after the tune was completed?
BTW, awesome info, where do you find the time for this?
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
12-20-2007, 06:57 PM
I see why you don't want to debate tuning with the SERT....so I won't start one but I do have to say, sorry, I don't agree with your method, and leave it at that.
12-20-2007, 07:12 PM
The pictures are linked from my webserver. Try refresh and see if that helps, if not right click on one of the red X's and select "Show Picture". If it still doesn't work see if you can get to our website, it may be a temporary thing.
207-621-8089
12-20-2007, 07:17 PM
No we disabled them.
207-621-8089
12-20-2007, 07:49 PM
I don't have a problem debating tuning with a SERT, it is our preferred device. But I am not going to debate AFR vs 4 Gas tuning. Not all have to agree with our preference.
207-621-8089
12-20-2007, 11:53 PM
BEADMAN
Working fine now. Thanks Springer, pretty amazing difference huh? Pretty sure a guy could definately feel the difference in the pants!
12-21-2007, 12:54 AM
Good work Springer
You disable the 02's by editing AFR table or by another method?
Just how close was the stage 1 timing map from the finished product?
Thanks for posting this.....
12-28-2007, 03:05 PM
To address a couple of questions asked about the bike tuned in this post;
Stock 96" with S.E. air cleaner and True Dual exhaust (I think they are Hard Chrome brand) that are 3" as soon as they leave the head all the way to the end (with whatever baffle came in them).
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
12-28-2007, 04:12 PM
Obsolete Rider
Great info
1998 Obsolete EVO Springer
Now boasting 85 cu in (well, almost)
01-04-2008, 03:17 PM
I'm gonna powder his nose
Some of the EFI hacks would prolly work on HD's
